Build 22621.1343, (KB5022913) Out to Release Preview Channel
2023-02-21T23:02:51+00:00
Releasing Windows 11 Build 22621.1343 to the Release Preview Channel | Windows Insider Blog
Done:
Edition Windows 11 Pro
Version 22H2
Installed on ‎1/‎28/‎2023
OS build 22621.1343
Experience Windows Feature Experience Pack 1000.22639.1000.0
Update on 2/28/2023, same kb# for Build 22621.1344.
Version 22H2
OS build 22621.1344
  1. Deleted
    2023-02-27T16:41:50+00:00
    This problem of Calendar crashing has been reported by @Silverpulser on Beta 22623.1325, but in my case, it failed with R.P. 22621.1343 while it worked fine in Beta build 22623.1325. 😎🤷‍♂️
    I did a Repair and then a Reset of the Mail and Calendar App and then it started working again. 😉🤷‍♂️
    2023-02-28T18:34:44+00:00
    02/28/2023. Same kb# new update for R.P. and Optional for Public Build. 22621.1344.
    2023-03-01T03:37:06+00:00
    This is quite puzzling.
    I am on R.P. channel with this system, and this showed up today 02/28/2023.
    Why am I offered a Beta Build on a system that is set for R. P. channel?
    It doesn't make any sense to me. 😎😎🤣🤣🤷‍♂️
    I did a pause/resume updates and it showed up the correct update after that. 🤷‍♂️
    Complete the update correctly:
    Version 22H2
    Installed on ‎12/‎20/‎2022
    OS build 22621.1344
