Build 22621.1343, (KB5022913) Out to Release Preview Channel
2023-02-21T23:02:51+00:00
Releasing Windows 11 Build 22621.1343 to the Release Preview Channel | Windows Insider Blog
Done:
Edition Windows 11 Pro
Version 22H2
Installed on ‎1/‎28/‎2023
OS build 22621.1343
Experience Windows Feature Experience Pack 1000.22639.1000.0
Update on 2/28/2023, same kb# for Build 22621.1344.
Version 22H2
OS build 22621.1344
    2023-02-26T06:47:36+00:00
    I don't understand this statement in the blog:
    • New! This update enhanced the system tray (formerly called the notification area). All icons had a rounded focus and hover treatment in the lower right, including the “Show hidden icons” flyout menu. You could move icons to rearrange them in the “Show hidden icons” flyout menu or move icons to the taskbar.
    What do the mean with "rounded focus" and "hover treatment"?
    I don't see any difference from what it was before this update, what is changed from previous build?
    To me it looks the same in current public build. 🤷‍♂️
    2023-02-26T23:01:18+00:00
    In this case the bug with Widgets was reported through FBH by users that saw the problem as soon as the faulty update came down.
    That is why we got a fix relatively quick the next day.
    The users that checked the MS Store for updates got the fix the next day, but not every user checks for MS Store updates on a regular basis. It is just something to keep in mind when dealing with Apps issues. 🤷‍♂️
    On this point about checking for apps updates: I did just that today. Without doing anything other than looking into the MS Store library, I saw that many apps had been "modified" moments before. It looked like others had been updated on the same day as the cumulative update. I kind of expected things to work this way and yet my Experience Pack had evidently not been updated like the rest.
    2023-02-26T23:12:14+00:00
    The faulty Windows Web Experience Pack 5100 came down a little later than the cumulative update, depending on when the users did the update, they may have hit the bug or not. The fix came down a day later with version 5300 and later 5400. 🤷‍♂️
    There is also a setting to do the updates automatically from the store, but you never know when it happens. 😎
  4. Deleted
  5. Deleted
