Depends on what type of problem you have. 😉
winget uninstall --id 9MSSGKG348SP
winget install --id 9MSSGKG348SP
Winget uses the id for the application to be installed.
Assuming MS does not change it to a different id, it should work again.
Anyway, there are also other ways to remove and reinstall an application. 🤣🤣
True enough, except that this widget app doesn't seem to appear in other places where you'd expect to see apps (Control Panel or "start" and then "all apps"). Widgets does show up under "settings" then "apps" then "default apps," but no obvious way to remove or to check for updates.
The other good news is that having updated this app, my other problem of mouse actions being delayed or blocked seems to have disappeared.
All to say, Microsoft, if you guys are going to make an app not functional in one of your cumulative updates, how hard would it be to update that app as part of the cumulative update? Why irritate users with idiotic malfunctioning software, when this is so easily avoided?
(For Dell users, I had a similar problem with poor performance, blocked actions, when I installed the Dell Optimizer package. I had to go to Task Manager, see what process in the world was causing the busyness, and then research online what was launching that process and why. Problem solved by removing Dell Optimizer. Damn, why do these guys love to lay these traps for people. Fortunately, Dell Optimizer is completely optional and does not install when you scan for driver updates at Dell Support.)
