Build 22621.1343, (KB5022913) Out to Release Preview Channel
2023-02-21T23:02:51+00:00
Releasing Windows 11 Build 22621.1343 to the Release Preview Channel | Windows Insider Blog
Done:
Edition Windows 11 Pro
Version 22H2
Installed on ‎1/‎28/‎2023
OS build 22621.1343
Experience Windows Feature Experience Pack 1000.22639.1000.0
Update on 2/28/2023, same kb# for Build 22621.1344.
Version 22H2
OS build 22621.1344
    2023-02-25T01:51:06+00:00
    It sure does, it reinstalls the latest available. But he should have checked what he had installed. 😎
    Not even curious?
    I tried to run the command you showed, but I tried with the command prompt, in admin mode, not with PowerShell. Maybe that's why it didn't work.
    Then, when I discovered that mistake and started using PowerShell, Sibro's message came on. So WTH, that seemed like a quick try to fix it once and for all. I did. It did.
    2023-02-25T02:19:55+00:00
    Not even curious?
    Run the power shell command as admin now so you can see how to verify the installed version of that App.
    You may learn something new for next time.🤣
    2023-02-25T03:57:49+00:00
    Hi Sibro,
    Got yet another newer Version a few minutes ago. 😎🤷‍♂️ Same version in R.P. and Beta.
    2023-02-25T19:44:50+00:00
    He may still have the failing version of W.W.E.P. it is an easy check. 😎
    AFAIK, uninstalling and reinstalling takes care of WWEP
    Not even curious?
    Okay, belatedly, I did what fg2001 insisted on, using PowerShell in admin mode, and it now shows:
    MicrosoftWindows.Client.WebExperience_423.5500.0.0_x64__cw5n1h2txyewy
    My question is, in the future if this happens again, will Sibro's instructions work?
    Open a cmd prompt with admin rights, copy and paste this command
    winget uninstall MicrosoftWindows.Client.WebExperience_cw5n1h2txyewy
    Restart
    winget install 9MSSGKG348SP
    And by the way, restart needed here too.
    Is that 9MSSG348SP generic to the newest, or specific to today's newest? I am guessing the former. And finally, why didn't Microsoft install that in the cumulative update, if whatever older version we had wasn't going to work?? I mean, that's just annoying.
    2023-02-25T19:57:54+00:00
    Not even curious?
    Restart
    Depends on what type of problem you have. 😉
    winget uninstall --id 9MSSGKG348SP
    winget install --id 9MSSGKG348SP
    Winget uses the id for the application to be installed.
    Assuming MS does not change it to a different id, it should work again.
    Anyway, there are also other ways to remove and reinstall an application. 🤣🤣
