Build 22621.1343, (KB5022913) Out to Release Preview Channel
2023-02-21T23:02:51+00:00
Releasing Windows 11 Build 22621.1343 to the Release Preview Channel | Windows Insider Blog
Done:
Edition Windows 11 Pro
Version 22H2
Installed on ‎1/‎28/‎2023
OS build 22621.1343
Experience Windows Feature Experience Pack 1000.22639.1000.0
Update on 2/28/2023, same kb# for Build 22621.1344.
Version 22H2
OS build 22621.1344
  1. Johnny55 5,155 Reputation points Volunteer Moderator
    2023-02-22T01:12:05+00:00
    Where do they hide the version numbers for Store apps now?
    2023-02-22T01:04:44+00:00
    Hi Johnny,
    Weird coincidence or maybe not. 🤣🤷‍♂️
    I just got the problem on Beta 22623.1325 right after it updated Windows Web Experience Pack to the version below:
    Here is the link to the FBH report:
    https://aka.ms/AAjr86i
    A few minutes later the same update on 22621.1343, screwed up this too. 🤣🤣🤣
    Time for an FBH report. 🤐
    2023-02-22T00:49:37+00:00
    Hello fg,
    I redid all my virtual machines with up-to date images over the past week, including an ISO for 22621.1265 for Release and RP. WU updated to 22621.1343 but first obvious concern, it destroyed the widgets that were working properly. It did give the Search options that I could toggle from box to icon. Thanks MS.
    Regards,
    Hi Johnny,
    Looks fine here. 🤷‍♂️
    Windows Web Experience Pack Version 423.4400.10.0
  4. Johnny55 5,155 Reputation points Volunteer Moderator
    2023-02-22T00:34:55+00:00
    Hello fg,
    Regards,
