CO-Release Build 22000.160 out to Dev and Beta Channel KB5005189
CrazyKats 19,415 Reputation points Volunteer Moderator
2021-08-19T17:00:15+00:00
Live in W.U.
    2021-08-26T02:47:21+00:00
    Hi Johnny,
    That is what I found and posted earlier, when I list all the names with Power Shell, but it does not match the name that was showing coming down from the store, also I don't see in it in the list of Settings -> Apps -> Apps & features nor a way to reset it other than using Power Shell commands.
    MicrosoftWindows.Client.WebExperience MicrosoftWindows.Client.WebExperience_421.20014.145.0_x64__cw5n1h2txyewy
  2. Deleted
  3. Deleted
    2021-08-26T03:19:29+00:00
    The only link I found talking about Web Experience :
    Windows Web Experience Pack shows up in Microsoft Store (winaero.com)
    Get Windows Web Experience Pack - Microsoft Store
    Can find it and install it in Windows 10, but not in Windows 11.
    I see this below on Windows 11, but this app is not showing on the list of Settings -> Apps -> Apps & features
  5. Drew - 810 Reputation points
    2021-08-26T05:41:03+00:00
    Seeing your entries made me curious. "Windows Web Experience Pack" was not familiar to me, but Windows Feature Experience Pack is. So, I looked around on both 10 & 11 at the Apps and in both Stores and came up empty everywhere. Maybe it's 2 different things. The only place I knew of it is Settings > System > About.
    It may have to do with Widgets. The Edge Widget is actually called the Web Widget. And the Win11 Widgets are built on the same platform as the Edge Web Widget... and N&I... the 3 of them are siblings, so to speak.
    Edition Windows 10 Pro
    Version 21H1
    Installed on ‎20-‎May-‎2021
    OS build 19043.1165
    Experience Windows Feature Experience Pack 120.2212.3530.0
    Edition Windows 11 Pro
    Version 21H2
    Installed on ‎30-‎Jun-‎2021
    OS build 22000.160
    Experience Windows Feature Experience Pack 1000.22000.160.0
    Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/e75dd14b-0179-4baa-a6be-d4ffff886123?platform=QnA
