CO-Release Build 22000.160 out to Dev and Beta Channel KB5005189
CrazyKats 19,415 Reputation points Volunteer Moderator
2021-08-19T17:00:15+00:00
Live in W.U.
    2021-08-25T22:52:12+00:00
    Hi Johnny,
    F.Y.I.
    I did a few more tests about the Solitaire Collection continuous update bug, I can confirm that it only failed on machines that do not meet the Windows 11 Requirements. It is not clear why, but that is the way I saw it.
    I switched the 2 machines that are fully compliant from Beta to Dev and they still don't show the problem.
    If I uninstall and reinstall the App, it is downloaded and installed once through Xbox and it does not try to update again.
    The behavior is exactly the same in Beta channel or Development channel for this Solitaire app.
    The only difference in Dev are a few more apps including MS Store and Snipping tool which are now at a higher level.
    The Solitaire bug is not happening at all on these fully compliant machines. It is not just a coincidence.
    I saw this already when I had the Dell XPS 8930 in Dev channel weeks ago, but now I can confirm it on 2 different machines.
    For some reason the bug only shows up on the non compliant machines.
    Keep in mind that the desktop was a clean install of Windows 11, but the Lenovo Laptop was an update from 19043.1165 to 22000.160.
    They both seem to behave exactly the same way.
  2. CrazyKats 19,415 Reputation points Volunteer Moderator
    2021-08-25T23:20:03+00:00
    Anyone seeing this stuck in the Store today?
    I've tried both a Repair and a Reset.
    2021-08-25T23:27:44+00:00
    Hi C.K.,
    I saw updating it on both Development and Beta, no problems.
    Sometimes all it takes is an extra restart to get out of that stuck situation with Apps updates.
  4. Deleted
  5. CrazyKats 19,415 Reputation points Volunteer Moderator
    2021-08-26T00:19:01+00:00
    After Restart we went from bad to worse. LOL
