Thanks CK. Took a bit longer on my slow connection, but was finished in 13 minutes. All ok so far. Guess subsequent installs on the other PC's will be slightly faster, as they should use the existing data.
CO-Release Build 22000.160 out to Dev and Beta Channel KB5005189
CrazyKats
19,415
Reputation points
Volunteer Moderator
2021-08-19T17:56:16+00:00 -
2021-08-19T18:06:51+00:00 Downloading DEV channel build now.
Update: DEV channel build installed OK!
J W Stuart
.180???
2021-08-19T18:14:33+00:00 Still no auto-unhide of taskbar on alternate monitors. Still no show desktop (bottom right) on hover. Still no comments in blog or on my open feedback hub issue. I guess they are "working as expected." That stinks!
2021-08-19T18:39:02+00:00 Hi CK,
Just now downloaded and installed with No Hiccups to report on The Beta Cannel. Took only about 7minutes from download to restart.
