I'm going to try uninstalling & re-installing to see if that stops it repeating.
Nope... had me update some Xbox thing as it wanted to do Solitaire from there. But within a second or 2 it still keeps repeating Update Available.
I don't care about Solitaire enough anyway, so I'm just going to uninstall & be done with it. And as we know this is using Dev, not Beta.
Eddie, if you read this, it has already gone to FH by others, I believe.
We already tried that on Dev and reported that did not work.
