Having high CPU usage and lag whenever trying to update WIP "Cumulative Update for Windows 11 Insider Preview (10.0.26120.1542) (KB5041872)" build
2024-08-25T05:52:06+00:00
I am trying to update the build Cumulative Update for Windows 11 Insider Preview (10.0.26120.1542) (KB5041872).
However, whenever I attempt to download the update, it consistently gets stuck at 8%. When it reaches 8%, the CPU usage by the Windows Modules Installer spikes to 80-90%, causing the PC to become unresponsive and slow. The issue resolves after restarting the PC and pausing the update. However, the problem reappears as soon as I resume the update, making it difficult to use the PC smoothly. I have tried restarting the Windows Modules Installer and Windows update from the systems. But it still is not resolving.
2024-09-08T04:51:15+00:00
I managed to fix it on my machine. I uninstalled the Security Update for Microsoft Windows KB5041872 and the Feature Enablement for Beta Channel Preview Update KB5037898. After the uninstall I checked for updates, and it downloaded a (repair) update. Once that updated was installed and the PC restarted, checking for updates resulted in once again trying to install the KB5041872 update which managed to pass the 8% mark and fully install within seconds.
61 additional answers
    2024-08-30T15:18:09+00:00
    I want to report that I'm also having the same issue.
    Basically when the update is in progress it gets stuck at Downloading - 8% and the Windows Modules Installer Worker starts using 80 - 100% CPU. I first noticed this when Gaming and my frames dropped to 5 fps. I've tried stopping the Installer Worker and Windows update services, deleted the SoftwareDistribution folder and restarted my PC. The only change was that I had to redownload the Security Intelligence Update for Microsoft Defender KB2267602 but otherwise I still get stopped at 8% with 100% cpu usage
  2. CrazyKats 19,680 Reputation points Volunteer Moderator
    2024-08-30T18:38:34+00:00
    Just a suggestion:
    Go to Settings, Windows Update, Update History
    and scroll down to Uninstall Updates.
    Click that and look for KB5041871 for 26120.1350
    and uninstall it.
    Also open Task Manager, Services and stop the
    Windows Update Service.
    Reboot the PC and see if the .1542 update will work now.
    2024-08-30T18:51:27+00:00
    KB5041871 for 26120.1350 is not avaliable to uninstall.
    The oldest update avaliable to uninstall is KB5041872 (20/08/2024)
  4. CrazyKats 19,680 Reputation points Volunteer Moderator
    2024-08-30T19:37:16+00:00
    That's the update to .1542, so you already
    have that update successfully installed?
