I managed to fix it on my machine. I uninstalled the Security Update for Microsoft Windows KB5041872 and the Feature Enablement for Beta Channel Preview Update KB5037898. After the uninstall I checked for updates, and it downloaded a (repair) update. Once that updated was installed and the PC restarted, checking for updates resulted in once again trying to install the KB5041872 update which managed to pass the 8% mark and fully install within seconds.
Having high CPU usage and lag whenever trying to update WIP "Cumulative Update for Windows 11 Insider Preview (10.0.26120.1542) (KB5041872)" build
I am trying to update the build Cumulative Update for Windows 11 Insider Preview (10.0.26120.1542) (KB5041872).
However, whenever I attempt to download the update, it consistently gets stuck at 8%. When it reaches 8%, the CPU usage by the Windows Modules Installer spikes to 80-90%, causing the PC to become unresponsive and slow. The issue resolves after restarting the PC and pausing the update. However, the problem reappears as soon as I resume the update, making it difficult to use the PC smoothly. I have tried restarting the Windows Modules Installer and Windows update from the systems. But it still is not resolving.
61 additional answers
Pauli O 16,380 Reputation points Volunteer Moderator
2024-08-28T04:24:42+00:00 >Should I wait for a future insider update to resolve this issue?
Current updates released in Dev channel are Cumulative Updates and if you have issues with installing current C.U. then it could be possible that there will be same issues also on future updates. You can try to run Recovery/Reinstall now or wait next C.U. (released end of this week?) to see if it fix your issue before running that reinstall.
2024-08-28T08:48:24+00:00 I have the same problem - downloading Cumulative Update for Windows 11 Insider Preview (10.0.26120.1542) (KB5041872) is stuck on 8% causing 100% CPU ussage! Waited 2 hours but still no change.
I am currently on Dev Insider channel running build 26120.1542.
2024-08-28T12:10:37+00:00 Even after 8 hours (to match the 8% lol) and even stopint bits, wauser etc.. like some of the posts. renaming catroot2 etc..
Starting anew , showed up 3% but stuck. at 8% with 99% of cpu used..Microsoft you are killing the planet! should I file a "Global Warming ticket to get our attention?" lol...
2024-08-28T14:35:20+00:00 Hey, you can just end the task in the task manager and then your system will run as before.
I think we need to wait for the next insider update so they can fix it.
