Build 25905 + ISO is out to Canary Insiders
CrazyKats 19,425 Reputation points Volunteer Moderator
2023-07-12T17:00:22+00:00
Live in W.U.
    2023-07-12T20:20:10+00:00
    Now we have both Dev and Canary screwed up! 🤬
    Except that Canary doesn't boot at all.
    Looks like they broke the New Button again on the Snipping tool. 🤷‍♂️😝
    Working fine here on this clean install. 🤷‍♂️
    2023-07-12T20:37:03+00:00
    That was always the case with clean install, it only happens when you have an old wrong association with MS-SCREENCLIP, instead of Screen Snipping they had Microsoft WinRT Storage API.
    Failing case:
    The Select default app is not working either.
    2023-07-12T21:17:25+00:00
    Thanks for the reminder, I wish I had good memory like yours.
    2023-07-12T21:21:00+00:00
    Added FBH report with recording:
    https://aka.ms/AAljkmd
    https://aka.ms/AAlkbyi
    2023-07-12T21:31:57+00:00
    Another silly variant for selecting the Background picture, it hides the taskbar and desktop for no reason.We already reported this in previous older builds.
    Probably another bad decision of A.I. it just does not get it. 😜🤷‍♂️
    https://aka.ms/AAlil5j
    This one is when MS removes the variant for the DesktopSpotlightRejuvenatedFlyout, it does not make any sense to me. 😝
    They should go back to the original variant 1.
    This is when MS uses the variant 1, make much more sense than the one above. 😉
