Build 25905 + ISO is out to Canary Insiders
CrazyKats 19,425 Reputation points Volunteer Moderator
2023-07-12T17:00:22+00:00
Live in W.U.
  1. Pauli O 16,380 Reputation points Volunteer Moderator
    2023-07-23T06:05:17+00:00
    >I just hope future canary updates will let us "Asus" users download via windows update.
    Future Canary channel builds should be available also for all ASUS user via W.U. as soon as they fix bug which caused bugcheck on some devices as mentioned in blog:
    "This build will not be offered to some ASUS devices or PCs with ASUS motherboards due to an issue causing a bugcheck when attempting to update to this build*".*
    2023-07-23T21:12:04+00:00
    @JohnthePilot
    @Pauli O
    Thank you for the input, makes me feel a lot better, really appreciate it very helpful. :) Take care!
