System & reserved files on a secondary drive?
2022-10-30T02:00:47+00:00
Beta build 22623.875 & Dev build 25231.1000
System > Storage > Advance storage settings > Disk & volumes > Disk 1 > Volume name > Properties > View usage
I didn't know about this until now, is this normal? why do we need system & reserved files on a secondary drive?
Windows Insider program | Windows Insider preview | Files, folders, and storage
2022-10-31T22:34:03+00:00
Copy back a few folders at the time and keep checking to see when those 14GB start showing up in the System files. Then you can isolate which one is causing the problem.
I followed your advise and copying folder by folder does not reproduce the issue.
However, if I copy everthing at once the 14GBs come back. πŸ€·β€β™‚οΈ
Thanks for the suggestion πŸ‘
Done and dusted!
Good that you could clean it up.
I guess we'll never know what caused the problem in the first place.
Perhaps when you got the BSOD?
Probably when you do a clone you copy over also the problem. 🀣🀣
57 additional answers
    2022-10-31T02:41:27+00:00
    Is there either one of these on the D: drive?
    Perhaps not cleared from previous installs?
    Nope! only the system volume information folder and recycle bin, that all.
    2022-10-31T02:42:29+00:00
    These 2 numbers on your screenshot look suspicious. 😎
    2022-10-31T02:50:41+00:00
    No other funny folders that could be setup by the system?
    You are not saying that the D: disk is empty, right?
    2022-10-31T02:57:23+00:00
    Never mind that.
    Please find those files on your drive, that will help me find my 14GBs
    No funny folders, hidden partitions nor hidden folders or files.
    D: is not empty of course not, the 120GB test drive was empty and newly formatted.
