System & reserved files on a secondary drive?
2022-10-30T02:00:47+00:00
Beta build 22623.875 & Dev build 25231.1000
System > Storage > Advance storage settings > Disk & volumes > Disk 1 > Volume name > Properties > View usage
I didn't know about this until now, is this normal? why do we need system & reserved files on a secondary drive?
Windows Insider program | Windows Insider preview | Files, folders, and storage
2022-10-31T22:34:03+00:00
Copy back a few folders at the time and keep checking to see when those 14GB start showing up in the System files. Then you can isolate which one is causing the problem.
I followed your advise and copying folder by folder does not reproduce the issue.
However, if I copy everthing at once the 14GBs come back. πŸ€·β€β™‚οΈ
Thanks for the suggestion πŸ‘
Done and dusted!
Good that you could clean it up.
I guess we'll never know what caused the problem in the first place.
Perhaps when you got the BSOD?
Probably when you do a clone you copy over also the problem. 🀣🀣
57 additional answers
    2022-10-30T23:50:43+00:00
    Did a second quick format on the same drive and now it shows 94.5 MB. 🀣
    The first time it was formatted by Disk Management, this time I just issued quick format from explorer.
    No idea on what they do different in the 2 cases. πŸ€·β€β™‚οΈ
    2022-10-30T23:55:16+00:00
    There are system files on every drive.
    You're right, I should have said System & reserved files. 😁
    Still, 14GBs of system files nowhere to be found ain't normal.
    2022-10-31T00:04:21+00:00
    That looks like a screw up, something is corrupted in the file system.
    Did you try a check disk?
    My properties screen looks quite different from yours. Here I show the used space on an empty drive just formatted.
    The other 2 below are the same as yours.
    2022-10-31T00:27:47+00:00
    Anything on this?
    You can use /F if it finds anything wrong.
    Seems like the File system on your D: drive could be screwed up.
    Maybe after the BSOD you had?
