System & reserved files on a secondary drive?
2022-10-30T02:00:47+00:00
Beta build 22623.875 & Dev build 25231.1000
System > Storage > Advance storage settings > Disk & volumes > Disk 1 > Volume name > Properties > View usage
I didn't know about this until now, is this normal? why do we need system & reserved files on a secondary drive?
Windows Insider program | Windows Insider preview | Files, folders, and storage
2022-10-31T22:34:03+00:00
Copy back a few folders at the time and keep checking to see when those 14GB start showing up in the System files. Then you can isolate which one is causing the problem.
I followed your advise and copying folder by folder does not reproduce the issue.
However, if I copy everthing at once the 14GBs come back. πŸ€·β€β™‚οΈ
Thanks for the suggestion πŸ‘
Done and dusted!
Good that you could clean it up.
I guess we'll never know what caused the problem in the first place.
Perhaps when you got the BSOD?
Probably when you do a clone you copy over also the problem. 🀣🀣
57 additional answers
    2022-11-01T03:20:34+00:00
    I'll leave it alone, unless I see any negative effect.
    Seems to work fine as it was setup by Windows. πŸ€£πŸ€·β€β™‚οΈ
    I meant "now" as a test. 😁
    I have plenty of space on C: no need to disable it permanently, but as the article describes, it could be useful when trying to install an update in low space conditions.
    How reserved storage works in Windows (microsoft.com)
