2 separate ISO files.
Hi FG,
They are the same ISO images of 26058.1000
Regards,
They may just set a different flighting channel. 🤷♂️
Why 2 ISO file if they are the same?
I would expect one 26058.1000 the other 26058.1100. 😎
They default to Dev channel on total clean install. I had to uninstall KB5036078 CU on my Canary VM to bring it back to .1000.
Well here is another week for 5 of my amd units to not be able to get the canary build
Then MS screwed up again. 😝🤷♂️
Why make us download 2 separate ISO files, if they are the same?
The 2 files are identical. What a ridiculous waste of time. 😜😜🤬
Come on MS you can do better than that. 🤬
Dev
02/14/2024 07:08 PM 5,145,939,968 Windows11_InsiderPreview_Client_x64_en-us_26058.iso
Canary
02/14/2024 06:22 PM 5,145,939,968 Windows11_InsiderPreview_Client_x64_en-us_26058.iso
