Build 26058 + ISO out to Canary/Dev Channel
2024-02-14T22:00:25+00:00
Live in W.U.
  1. Drew - 810 Reputation points
    2024-02-20T22:04:18+00:00
    You're very welcome. Glad I was able to help & thanks for you voicing appreciation. Yes, that will be good/much better 👍👍
    I have done it that way in the past, as well and it worked/works very nicely/well.
    Maybe, you would mark my suggestion as "Helpful". Oh, thanks, I think you did, already.
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/aef62765-10a6-4b6d-b097-27362d14eece?platform=QnA
  2. CrazyKats 19,760 Reputation points Volunteer Moderator
    2024-02-21T15:35:36+00:00
    I do not have the new Widget feature on my
    26058/Dev, but is anyone else's Widget opening
    on startup?
    I found the cause of this. If I turn off the
    open on hover over setting it doesn't happen. https://aka.ms/AAp97hg
  3. Drew - 810 Reputation points
    2024-02-21T21:13:25+00:00
    Well for what it matters, I do not have this issue no matter whether set to Hover or Click.
    Also, do others have the 'new' Widgets panel with all its new Settings in 'public' Win11 as well as IBs? (I have it in both)
    Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/1d60b0ec-85f3-4b66-958d-04b33a4c63de?platform=QnA
