Build 26058 + ISO out to Canary/Dev Channel
2024-02-14T22:00:25+00:00
Live in W.U.
    2024-02-20T04:26:08+00:00
    I just got this problem even after a clean install of 26058. Easily reproduceable on the machine.
    https://aka.ms/AAp536r
    2024-02-20T12:54:01+00:00
    (Windows 11 Insider Preview 10.0.26058.1100 (ge_release) download and install the updated version after disappeared wifi signal and cannot connect internet access. in this case how to fix any solutions ?
  3. CrazyKats 19,760 Reputation points Volunteer Moderator
    2024-02-20T13:54:18+00:00
    I've had the same issue for several builds.
    Usually a Restart fixes it for me.
    https://aka.ms/AAos19k
  4. Neil D 34,310 Reputation points Volunteer Moderator
    2024-02-20T21:10:44+00:00
    I took your suggestion and now have the latest Dev build installed on another partition so using the hardware directly, as you said.
    Much better now so thanks Drew.
    2024-02-20T21:55:06+00:00
    If you install 2 windows 11 systems on 2 partitions of the same disk you may want to check out this problem below.
    https://aka.ms/AAou263
