Snipping Tool issues with Build 25295
2023-02-11T14:14:11+00:00
Split from this thread.
Sure did. Tried also repair and reset.
It didn't help.
Would be nice to be able to install older versions in cases like this.
Hi Sibro,
I solved the Snipping Tool problem by restoring 25284 and then upgrading to 25295 directly, skipping 25290.1000 and 25290.1010.
Snipping tool works fine now on the same machine that was failing when it went from 25290.1010 to 25295.1000.
Go figure!
What made me suspicious was that error on DCOM 25290.1010.
Windows Insider program | Windows Insider preview | Desktop environment and Start menu
    2023-02-19T04:08:11+00:00
    This wasn't A/B testing so it's hard to understand how they can screw up some machines but no all. 🤷‍♂️
    Same way that you still have the bug with contacts switcing and I don't on 3 different systems. 🤣🤣🤣🤷‍♂️
    2023-02-19T04:28:46+00:00
    Sure but hardly as important. The on/off selection sticks despite settings crashing plus I'm one in a million. 🤣
    2023-02-19T04:38:53+00:00
    No difference, the workaround for the snipping tool works too.
    Still, they are all bugs that need an explanation. 🤣🤣
    2023-02-19T04:52:02+00:00
    We will always agree to disagree on the importance of bugs. 😁
    Good night!
    2023-02-19T22:29:01+00:00
    Good night!
    B.T.W.
    My old Legacy MSI upgraded from 19045.2670 to 25300.1000 does not have either one of the 2 bugs.
    No problem with Snipping Tool nor the Contacts switching off and on. 🤣🤣
    None of the resolution issues on this machine contrary to all the problems in the newer compliant boxes. 🤣
    It sure has the most recent bug with the Phone calls settings crashing, which seems to be common to every 25200 system. 😉🤷‍♂️
