Only once here on that page. Check the other page at the bottom, in the related settings:
The other page shows it only once but it can be set to default from either page.
The problem is that originally it was not showing on the other page, it showed up only after I set it as default.
If I reset the defaults it does not show again. π€£π€·ββοΈ
A little confusion about the name too when searching for ms-screenclip as mentioned in the Blog.
That name only shows on one page not the other. π€£π€£π€£π
- [NEW] Weβre investigating reports that the New button in Snipping Tool isnβt working for some Insiders after upgrading to Build 25295. If you are impacted by this, going to Settings > Apps > Default apps, and setting screen snipping as the default for ms-screenclip, it should resolve the issue.
