Windows 11 Wifi Problem
2021-07-25T19:01:18+00:00
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
    2021-09-09T20:06:04+00:00
    What part of "we cannot connect to the internet" don't you understand??? We cannot download a driver.
    Your advice is useless.
    Come on man!!!
    Download the driver on the system that you are using to post here. Then transfer to USB stick to use on system that has issue.
    2021-09-23T09:22:28+00:00
    It will not work, I've tried several drivers and nothing....
    Even manually assigning network info, it will not work.
    Somehow the issue is only with Sent packets.
    2021-10-03T17:39:34+00:00
    I tried with USB tethering and Ethernet too .. but i didn't find any drivers tho ...
    2021-10-05T16:02:34+00:00
    its easy
    if your wlan card drive is work but off press win + R in keyboard **** then in run write services.msc then enter in services search for wlan autoconfig open it and change the startup type to manual and press ok try to made your wifi on it should work normal
    2021-10-11T04:49:31+00:00
    I own a dell inspiron 5570 i5 and after updating to windows 11 on 7th of October i m facing the same issue did everything you have mentioned above tried everything but not able to connect to the internet
