Same problem! Excellent speed, NO problems before I upgraded to Windows 11. Now nothing but crawling.
Windows 11 Wifi Problem
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
2022-02-10T00:41:41+00:00 -
2022-03-06T21:37:51+00:00 I am having the exact same problem. I have downloaded Windows 11 three times and each time I have lost my internet connection and can't get it back. I uninstalled Windows 11 and got it back each time. Now, I do not want to install Windows 11 but don't have any choice. l Not fair at all. I have pushed the date out as far as I can and now that date is fast approaching when I will have no choice as it will be installed automatically and I will be without internet. Help, what can I dol??
2022-03-09T15:54:07+00:00 I just downloaded the intel driver support assistant and update my Bluetooth driver. Then my wifi works fine now. Interesting though!
https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
2022-03-10T00:45:51+00:00 My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
All of the fixes I found did not work for me. Ultimately I found that the power management settings for the wireless adapter were set to "allow the computer to turn off this device to save power." Once I unclicked the box, my issue was resolved. This setting can be found via device manager>network adapters>Intel(R) Wireless-AC 900>right click>properties>power management
2022-03-10T16:33:12+00:00 This thread is long-running and is outdated given it was started back during the pre-release phase of Windows 11.
Closing it out to help parse other issues should they arise rather than having an "all in one" thread with a variety of topics in it.
Cheers!
