I am facing lot of wifi connection problems since 1 week. I am not able to fix the problem, can you please help me.
Windows 11 Wifi Problem
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
2022-02-07T14:57:17+00:00 -
2022-02-09T04:09:21+00:00 I downloaded Windows 11, and now I'm at a hotel connecting to their wifi. When I select the hotel's wifi, it opens up Edge for login. Except Edge blocks the site and won't display the page where I can enter my room number and password. I had to open Chrome and guess at the hotel link several times before I reached the correct one. How do I change the default browser for network and internet apps to Chrome for future logins? Thanks for your help!
Deleted
Deleted
2022-02-09T15:16:11+00:00 Not that easy if it is all ready saying Manual and Running is it???
