Im havibg the exact same problem.
Cant use the device at all now as there is no way to connect to internet with my Surface go 2
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
Same problems
I updated to window 11 but my wif won't work. When I go into device manager it shows an error with the wifi adapter - Killer Wireless-n/a/ac 1535 Wireless Network Adapter. I tried updating the driver but windows said it is the latest version. I tried uninstalling and reinstalling but to no avail. I have also tried resetting the adapter but again no luck. Does anyone have a solution?
Same problem here bro ..I updated 1 week ago .. it's work well...but today at the evening it's suddenly show no wifi available even the wifi options is also not available in the navbar and also in the system..and the bluetooth is also gone from the system ..I don't know what happened..... anyone who can help me in this...
