Windows 11 Wifi Problem
2021-07-25T19:01:18+00:00
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
    2022-01-26T22:24:17+00:00
    I had this issue before Christmas and it fixed itself after a day. Now having the same issue again, though the wifi is missing entirely. Ethernet works for some reason.
    I can't believe one of the biggest tech companies in the world has clearly known about this issue for months and have no solution. What a joke. I'm rolling back to Windows 10.
    2022-01-26T22:30:35+00:00
    I just had this exact issue and tried what you suggested. Worked like a charm, thank you so much!
    I really hope they update their useless fix suggestions with what you said. I literally tried a dozen different fixes and this is the only one that worked.
    2022-01-27T10:12:28+00:00
    My network card is an Intel(R) Wi-Fi 6 AX201 160MHz and I'm running on a Fujitsu U7310.
    I had two issues:
    Issue 1: having to connect manually every time I start the PC.
    Issue 2: constant disconnects and having to manually reconnect.
    After updating to Windows 11 I lost wi-fi connection once every 5 to 30 minutes and had to manually reconnect every time.
    What fixed the constant disconnecting (issue 2) for me was downgrading the network card driver to an older version. Previously I had driver version 22.90.0.5 from 27.09.2021 (I tried installing a newer one that was posted here, but it didn't take - might give it another try later on), but after downgrading to driver version 21.60.0.5 dated 11.11.2019 I haven't lost connection again. However, I still have to connect manually after turning the PC on, so there are still some kinks to work out.
    The proposed fix by Ackphfft didn't work for me - for either driver version. I didn't test if it affected the constant disconnects on the newer version, but neither versions connected automatically when I started the PC after holding the off-button for a whole minute.
    So issue 1 remains unfixed for the time being, but I'll be back if I find a solution.
    TL;DR: downgrade the network driver version if you keep disconnecting.
    2022-01-31T17:00:43+00:00
    Does Microsoft expect all it's users to be IT engineers? releasing semi finished product and asking people to fix it themselves??
    2022-01-31T17:01:49+00:00
    You would check for BIOS update?? seriously? that's like selling a car with a faulty exhaust and telling the customer how to fix it... joke!
