Hi SomaticBull65,
What is the make and model of your computer?
For your information the device manager only searches your computer so no longer searches the net for updated drivers.
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
Hi SomaticBull65,
Thank you so much. I'll have a look tomorrow, see what I need to do.
Same issue on Lenovo Laptop which comes with Intel AX200 wireless card. Now I tried to reinstall the driver which was download from the Intel website. And waiting for official optimization in the future release.
Hi Stephen.LeeHC,
I still have wifi problem but its getting less often now with the latest Insider 22504
the quickest way to get it working again that I have found is settings, network and internet, advanced network settings, network reset and then shut down my computer, wait a minute then boot up and hopefully all will work again.
I have a similar issue. Had this on my previous laptop with Windows 11. After starting up the laptop there is a short moment a connection, then it gets disconnected, although it says autoconnect.
Yesterday received my new laptop with W10. No problems, upgrade to 11 today and the problems start to come back.
It's easily solvable by connecting to the wifi, but it's still weird and now seen it on 2 devices (6 yo MSI-laptop and brand new Lenovo).
Update:
Found some possible solutions like disabling energy-saving mode or updating driver. Did both. Seemed to work for a few hours but then the problem returned and at one point my whole internetconnection wouldn't work. A case I also had a few times with the old laptop. Solution: rebooting. But being so fed up with these problems I did a downgrade to W10 and everything is back to normal. One thing: the issues I have I hadn't when I was running W11 developer version on my old laptop. It was introduced with the final W11-release.
