Windows 11 Wifi Problem
2021-07-25T19:01:18+00:00
My problem is that I'm in windows 11 on my Lenovo laptop, but after another beta update every time I turned on my laptop it would be disconnected from my Wifi and when I connect it to my Wifi it says connected no internet. So then I restart my laptop and it starts working again, but then later on the day the problem happens again.
*Moved from Windows 11
    2022-02-09T15:16:11+00:00
    Not that easy if it is all ready saying Manual and Running is it???
  2. Deleted
  3. Deleted
    2022-02-09T04:09:21+00:00
    I downloaded Windows 11, and now I'm at a hotel connecting to their wifi. When I select the hotel's wifi, it opens up Edge for login. Except Edge blocks the site and won't display the page where I can enter my room number and password. I had to open Chrome and guess at the hotel link several times before I reached the correct one. How do I change the default browser for network and internet apps to Chrome for future logins? Thanks for your help!
  5. BryceSor 5,500 Reputation points Volunteer Moderator
    2022-02-02T06:25:18+00:00
    Hi JogvanV
    I have been running this on the Dev channel and I have not had a problem since its been installed which is over a week now.
