Charging Problem in Windows 11
2021-07-02T06:33:52+00:00
laptop stop charging when i upgread to windows 11. However the charging sign shows costantly but there is no increase in laptop`s battery percentage
please suggest what should i do
Windows Insider program | Windows Insider preview | Performance and maintenance
    2021-08-27T06:02:20+00:00
    Plz whenever you have any serious issues like this then plz also report this issue in feedback hub as well so Microsoft see the issue and will fix it in next build.
    I'm also facing the charging issue in Windows 11 on my brand new MSI laptop after upgrading Win-10 to 11.
    No restart will work.
    2021-09-10T09:57:02+00:00
    I experience the same, after I upgraded to windows 11.
    2021-09-10T21:45:33+00:00
    I also had this problem. I am also using a Dell Inspiron 5577 laptop. I also updated the to the latest build of windows.
    in the bios i set the charging to standard where it was set to adaptive.
    The light on the laptop does not go amber to show it is charging but the level indicator is now going up
    hope this helps!
    2021-09-12T11:38:50+00:00
    hope this helps!
    I am currently experiencing this one now. How do I update the charging from adaptive to standard? Many thanks!
    2021-09-14T05:34:39+00:00
    hope this helps!
    Same problem, but with Surface Pro 7.
    Charger LED lights up, battery icon shows the plug, but it's not actually charging. Even when the charger is disconnected, the battery icon still shows battery + plug (charging) icon.
