Charging Problem in Windows 11
2021-07-02T06:33:52+00:00
laptop stop charging when i upgread to windows 11. However the charging sign shows costantly but there is no increase in laptop`s battery percentage
please suggest what should i do
Windows Insider program | Windows Insider preview | Performance and maintenance
    2022-01-18T17:12:33+00:00
    bro if u resolved issue tell me how u did
    2022-01-26T18:52:47+00:00
    I have a Dell G3 15 laptop, which worked perfectly fine until I had the Windows 11 update, after this the battery stopped charging, however still showed it had a power source plugged in and the battery is healthy. I have since changed the charging port, tried a new battery and a new charger which has still not solved the issue. I have also tried disabling the ACPI compliant control method battery etc and still have the same problem and also reinstalling other drivers. The battery is showing at the same charge regardless of all of this. Can anyone advise or help please?
    Thank you in advance !
    2022-02-02T22:33:58+00:00
    I have the official version of windows 11 on my laptop and since I have updated it I have been having the same issue. Please advise
    2022-02-05T12:05:21+00:00
    Hi, any luck with the battery?
    After windows 11 update, my battery is stuck around 85% and it never charges.
    I have done the hub thing as a feedback, but nothing yet.
    2022-02-07T09:16:56+00:00
    Same problem I am facing here. HP-Pavillion cc153-tx. Tried a lot by uninstalling the battery management system.
    I was working smoothly on win10 with almost about 3 and half hours of battery backup. But after upgrading to win11, it's a **** backup. Can't operate my laptop for more than 30min with minimum brightness. Draining battery while I shutdown my laptop also.
    Microsft always brings something worst while we working better.
    Please resolve, or we have to forcely go back to win 10 again. Also, we have to turn off permanently win updates.
