Can you send a screenshot of your battery graph? System>Power and battery.
Insider builds are buggy and bound to have issues.
laptop stop charging when i upgread to windows 11. However the charging sign shows costantly but there is no increase in laptop`s battery percentage
please suggest what should i do
sorry bro but now i don't have Windows 11 installed on my system now. because if my laptop is not charging , i have to switch to WINDOWS 10 in order to use it.
Me too facing this issue . Please respond . Is it working fine on rolling back to windows 10?
Hi.
Since Windows 11 is a beta ( preview ) software, there may be glitches and annoyances until it is released to public.
I only wished you had filed a feedback hub report before you restored to your earlier OS.
You may try it again later when bugs are squashed out and rough edges ironed out, if you so wish.
Happy computing.
Plz whenever you have any serious issues like this then plz also report this issue in feedback hub as well so Microsoft see the issue and will fix it in next build.
