APC INDEX MISMATCH when I launch roblox.
2025-03-02T12:18:28+00:00
basically the title. i have tried everything: bloxstrap, plain roblox. even the roblox from Microsoft store. it just randomly crashes since yesterday. it does not work anymore today. any way to troubleshoot this?
by the way it is a green screen of death
Windows Insider program | Windows Insider preview | Microsoft Store
    2025-03-04T20:38:51+00:00
    Rota, my son gets the same thing, only with Roblox.
    Mini Dumps: https://1drv.ms/f/c/dba4c6510897b07e/EofHod63NNNLi1HftQ4GNbQB6tj8YEjxe_dm2vr-mQZ95g?e=jWehRY
    I have disabled Audio Driver
    Downgraded Video Driver
    RAN SCP / DISM
    He even reinstalled Windows
    Thank you,
    Robert
  2. BryceSor 5,500 Reputation points Volunteer Moderator
    2025-03-03T02:32:21+00:00
    Hi Speedrunner_349,
    Running games on Insider can cause trouble, type winver in search open that app and post back the Insider build you are on.
    GSOD = Insider install.
    BSOD = public or consumer install.
    2025-03-03T02:17:56+00:00
    Hello,Speedrunner_349
    Welcome to posting in the Microsoft Community.
    I understand your problem very well, it's really a headache to encounter this situation. But don't worry, we can analyze and try to solve this problem step by step.
    First of all, a green screen of death usually generates some dump files which record important information about the system crash and are very helpful in diagnosing the problem. You can try to check if your system is properly set up to generate dump files and follow the steps below:
    • Left-click Start > Settings > System
    • On the System page, click “System Information” - “Advanced System Settings”.
    • In the “Startup and Repair” option box, select “Settings”, adjust “Write Error Message” to “Memory Dump”, and click “Dump”. “Click “OK”.
    • After the BSOD error occurs again, the system will automatically collect the error message and store it in the Minidump folder under C drive, you can upload this file to the cloud and share it with me.
    In the meantime, we recommend you to check the error log in the Event Viewer. The Event Viewer logs detailed information about the system's operation, especially errors related to the video card or network card. You can follow the steps below to view the logs:
    • Right-click on the Start Menu and select Event Viewer.
    • In the left menu, expand Windows Logs and select System and Applications.
    • On the right side, view the error log when the crash occurred.
    From your description, it seems that the more common cause of this problem is an incompatibility between the graphics card driver or the network card driver. Especially when running a program like Roblox, it is very important that the graphics rendering of the graphics card and the network connection work together. Crashes and green screens of death like these can be triggered by incompatible versions of the graphics card or network card drivers, or by problems with the drivers.
    To better help you analyze the problem, you can be bothered to recall the following points:
    • When did the problem start?
    • For example, have Windows, graphics card drivers, or other hardware drivers been updated recently?
    • Has new software or tools been installed?
    • Some third-party software may conflict with the system and cause instability.
    Going through the above steps will provide us with some tips on how you can share more information with me and I will investigate this further for you. Thank you for your understanding and cooperation!
    Best Regards,
    Rota|Microsoft Community Support Specialist
