Build 25324.1011 + ISO is out to Canary Channel
CrazyKats 19,595 Reputation points Volunteer Moderator
2023-03-23T17:00:32+00:00
Live in W.U.
    2023-03-24T04:12:19+00:00
    Went to grab 25324 today. No error messages, no Retry, but keeps going through partial Install (maybe 25%) and then goes back to Downloading, several times. Have never seen this behaviour with any Build previously. Maybe it will complete one of these times 🤞
    Read the post from Jason[MSFT] earlier on this thread page 2.
    2023-03-24T06:34:57+00:00
    Upgraded one desktop from Beta 22624.1470 to Canary 25324.1000. No upgrade issues.
    Edition Windows 11 Pro Insider Preview
    Version 22H2
    Installed on ‎3/‎23/‎2023
    OS build 25324.1000
    Experience Windows Feature Experience Pack 1000.25324.1000.0
    This update came down with W.U. after the upgrade:
    2023-03-24T07:04:47+00:00
    Check if the following registry entry is set:
    Key: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\System
    Entry: RunAsPPL
    If so, that's the reason you can't change it in the Defender UI.
    You can delete it and configure it in the UI afterwards.
    @pwnosh,
    Looks like this is a confirmation of your point. 😉
  4. Drew - 810 Reputation points
    2023-03-24T07:15:11+00:00
    Thanks, I have just read it. And on the bright side, patience is a virtue, as they say... mine did, at long last, decide to go all the way through and complete 😃👍👍👏 I started (trying) sometime mid-afternoon and finally success at around 1 AM.
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/22389daa-ddbb-479d-a53c-c974f7419b52?platform=QnA
    2023-03-24T07:23:57+00:00
    That's a long time.
    I only had one bounce on the first machine I updated with W.U. and it worked fine on second attempt. 🤷‍♂️
