That's the point... it did not show after the workaround was done, in the previous Build. In 695 both were listed; The unneeded one was subsequently deleted.
It might not have been 100% clear as initially said or 'described'
This problem started for me with 27686.1000 and still happening with 27695.1000.
It is inconsistent, gets this message on some machines and not others at the same build level.
Also reported by other users with Build 24H2.
win11 24h2 bug - Microsoft Community
Only happens in Safe Mode, the PIN works fine when booting in normal mode. 😵💫🤷♂️
