Tools and settings that filter and block explicit or inappropriate content from search results.
I fixed it by changing the encrypted DNS setting from Cloudflare, to Google, restarting Edge and then changed it back to Cloudflare.
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Thanks for your reply but bit to techi for me how do I change those settings.
Thank you Terry.
All the suggestions: Go to Bing, then 3dots, then Settings, then Search or Safesearch. That is where I get stuck there is no SafeSearch option no matter which path I take. I have the same problem as being told I live in a restricted area of somekind. England?
I am restricted even to getting to charity sites, TV channel sites and many more. Even Disney fror my G'son. This problem is affecting many and should be resolved.
Windows 10 Pro 19044.2130
I still cannot change it "You don't have permission to change your SafeSearch setting. It's locked by safety settings applied to this browser."
Other browsers work normally and you CAN change safe search but on Bing ''YOU CANNOT CHANGE THE SAFE SEARCH SETTINGS WHY?''
