Tools and settings that filter and block explicit or inappropriate content from search results.
Many thanks.
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Many thanks.
Mine has been like this for years - must be something with having access to office via school or something but i think all of those are quite old now... no one has ever had a solution
I fixed my issue by witching to a Windows 11 Pro License key I got in a sale for $33. It was Education Edition causing the problem for sure.
I have windows 11 pro. No education version.
