Bing safesearch stuck at "strict" on Edge
2022-02-16T09:34:31+00:00
Recently, I discovered that when I browse Bing using Edge on my desktop, SafeSearch appears to be fixed on "strict" when it was "off" previously.
When I attempt to change this setting, I see the following message with no options to change SafeSearch permissions:
"Your country or region requires a strict Bing SafeSearch setting, which filters out results that might return adult content."
I live in the US, so this is definitely incorrect. Using a VPN to switch countries does not allow me to change the setting.
I am able to change SafeSearch settings when using a different browser and/or using a different device and Edge, so the issue appears to be specific to my desktop and Edge. I am using a Windows 10 Education key that I bought almost 5 years ago.
How do I turn off SafeSearch when using Edge on my desktop?
Edit: Only solution was to move to a different Windows 10 version. Seems to be an issue with Windows 10 Education and usergroup policy. I'm not IT savvy enough to find out how to change that, so the nuclear option of downgrading to a different version of Windows 10 was my only option. Hope this helps others that have this issue.
Bing | Safety and privacy | Adult content and SafeSearch
    2023-05-23T05:21:34+00:00
    As long as the Safesearch settings are visible, people are going attempt to change the settings.
    When people realize they can't change the setting, they come to this forum to vent their frustrations.
    Microsoft needs to completly eliminate this Safesearch aberration.
    2023-06-29T17:21:26+00:00
    But I SHOULD be able to change the settings! I am running Windows 11 Pro on a home machine. There is no one creating a policy to block me. And yet, I don't seem to be able to get past this SafeSearch situation.
    2023-06-29T22:54:18+00:00
    If you are pro, you are correct there should be nothing stopping you from changing the setting. It is only education and enterpise windows that strict safesearch is forced on. So you have a different issue going on than the people in the thread including myself are having.
    2023-08-05T08:17:26+00:00
    I have the same issue. It actually happened after installing AVG secure browser and I thing it changed something in the settings that I can't work around.
    2023-08-15T21:58:22+00:00
    The solution is very easy. Visit www.goole.com in MS Edge and search for anything you want (after turning off google safe search)
