Why Does Microsoft Rewards Have So Many Issues, And Why Does It Keep Getting Worse With More Bugs And Gltiches In The System?
2024-04-15T05:02:56+00:00
Hello Microsoft!
I've been losing so much trust with Microsoft Rewards. There is a specific issue I'm having and I detailed it as much as I could using the support form: https://rewards.bing.com/support and when they responded to me, they were confused about the issue as well. They said they looked into it, but they haven't gotten back with me. I always lose a streak because the suport team can't help. And when they've helped (when they were good in the past), they've restored my streak from their website bugs, however, when it happens because of a bug again, they refuse to restore it, even though they know it's not my fault that their system glitched out. They didn't give me any free points for compensation, and now they're just getting worse. I'm starting to think if they actually really care, because honestly, they have a weird way of showing it.
I truly believe they aren't doing the best that they can. There needs to be some order in this, to ensure that the bugs I'm currently experiencing don't happen to me or anyone else ever again. This program has been around for years and it was so much better back then than it is now. I understand that some bugs may be confusing, but it's THEIR site at the same time, so it's THEIR job to know what goes wrong, immediately find the issue and fix it, ensuring that it isn't likely to happen again. This is exactly what they're NOT doing.
If you can give me tips on how I can get into contact with them more effectively than through a link where I can't send images of my issue to them, I'd greatly appreciate it.
Thanks!
-Josh C.
Bing | Microsoft Rewards
  1. Deleted
  2. Deleted
    2024-09-02T19:54:56+00:00
    yes I use the rewards assistance for help but not enough for myself to complete activities on feeling symptoms, must help me on that immediately.
    2024-09-02T21:07:14+00:00
    You have to click on where it says Feeling Symptoms.. it will bring you to the bing.com page. Then just put in "flu symptoms" and hit search
  5. Deleted
