Don't do it if you're playing from Asia region. For some reason the 100 rp does not get redeemed in the correct region. I once tried to redeem the 100rp just to try it since I had extra redeem points, on my Valorant account and it said region mismatch. But the 575 one works just fine. I then had to submit a ticket to Riot to kindly help me load that other region vp into my account. You can't do it by yourself and you'll just end up losing the points. I was lucky to get help from riot to get the 75 vp sent directly into my account. It may not always work.
