How can I disable Copilot in Bing search engine?
2024-02-19T16:58:07+00:00
The most annoying feature by Microsoft on a miniature scale when using mobile devices.
Scrolling through search results when using Bing search engine on mobile devices automatically switches over to the Copilot tab. There should be a switch in Search Settings (attached pictures) to disable Copilot in all search results.
Bing | Search | Share and social search results
John Jefferson Doyon 87,635 Reputation points Independent Advisor
2024-02-19T17:44:27+00:00
Hi there, I am John J.D., a fellow Microsoft user like you.
I understand your frustration. Unfortunately, there isn't an option to disable Copilot in Bing's search engine settings, as it's integrated into the browsing experience. We're all users here, and Microsoft employees don't often visit the community, you can provide direct feedback to the Bing team by using the Feedback option at the bottom of the search results page.
In the meantime, I recommend downloading the Microsoft Edge app or the Bing app, as this feature isn't present in those platforms. I understand how frustrating this can be, and I hope this workaround helps improve your search experience.
Should you need any further information, please let me know.
John J.D.
Just a quick update:
The Microsoft Bing team has added a feature to disable the function that opens Copilot/Bing chat when scrolling down or attempting to refresh the page.
You can disable this feature by clicking on the Menu icon (≡) and toggling off "Scroll to open Copilot".
Our feedback has been heard. Congratulations!
John J.D.
86 additional answers
    2024-07-16T01:17:30+00:00
    Already done, doesn't work.
  2. Drew - 810 Reputation points
    2024-07-16T03:51:14+00:00
    Then, one can just not use it if, one thinks one should hate it.
    Personally, still, feel there is no need or reason to remove or to want to remove, anyway. No harm, no foul.
    Maybe, in time, people will come to appreciate having it 🤷‍♂️
    Cheers,
    Drew
    ![](https://learn-attachment.microsoft.com/api/attachments/73baeb64-5c5c-45f5-a504-055a0b9f0880?platform=QnA
