How can I disable Copilot in Bing search engine?
2024-02-19T16:58:07+00:00
The most annoying feature by Microsoft on a miniature scale when using mobile devices.
Scrolling through search results when using Bing search engine on mobile devices automatically switches over to the Copilot tab. There should be a switch in Search Settings (attached pictures) to disable Copilot in all search results.
Bing | Search | Share and social search results
John Jefferson Doyon 87,640 Reputation points Independent Advisor
2024-02-19T17:44:27+00:00
Hi there, I am John J.D., a fellow Microsoft user like you.
I understand your frustration. Unfortunately, there isn't an option to disable Copilot in Bing's search engine settings, as it's integrated into the browsing experience. We're all users here, and Microsoft employees don't often visit the community, you can provide direct feedback to the Bing team by using the Feedback option at the bottom of the search results page.
In the meantime, I recommend downloading the Microsoft Edge app or the Bing app, as this feature isn't present in those platforms. I understand how frustrating this can be, and I hope this workaround helps improve your search experience.
Should you need any further information, please let me know.
John J.D.
Just a quick update:
The Microsoft Bing team has added a feature to disable the function that opens Copilot/Bing chat when scrolling down or attempting to refresh the page.
You can disable this feature by clicking on the Menu icon (≡) and toggling off "Scroll to open Copilot".
Our feedback has been heard. Congratulations!
John J.D.
86 additional answers
    2024-06-13T00:16:22+00:00
    You like it. I hate it.
    Microsoft should give US the choice.
    I never asked for it, was never asked if I wanted it, and can't get rid of it.
    How do you find this mess that is Copilot helpful?
  2. Drew - 810 Reputation points
    2024-06-13T02:41:43+00:00
    DO have choice.
    There is no need or reason to "get rid of it"... just don't use it, don't > it, don't click on tab or icon for it.
    If you are open-minded enough you learn all about the multiple talents & abilities Copilot has... much of is besides & beyond any search engine basics. There are heaps of things you can, create... it's just cool, all sorts of areas where it's a whiz. And it's full of options/choices including its use, at all or not. Anyway, if you want, discover it **** HERE.
    And there is more interesting info HERE.
    It's brilliant what it can do, offer, great time-saving.
    Can be personalised.
    Much more than search... can help with heaps of things (for you/with you) and create such cool stuff expressing your ideas... and it goes on & on. It's quick, powerful, useful, great to have handy.
    NB: You need not spend any time nor attention on the Copilot Pro or higher parts. Free, only. 1st column.
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/88657ff1-6b8a-4182-8c38-a18f2d88b188?platform=QnA
    2024-06-21T13:39:02+00:00
    I tried the disable features and they don't work. I am trying to do just a simple phrase search to complete a cut off text for work and can't get past co-pilot introducing itself. This is preventing me from doing my job. I have left feedback but I'll have to find another search engine as this is untenable. I would rather have an opt-in or some such so I can choose to use it rather than being forced to train the AI with my work.
    2024-06-21T13:40:58+00:00
    It's not allowing me to choose. I enter a search term and it pops up. I;ve tried disableing. I've searched the site trying to find a choose option. Nothing. I have now spent 30 min trying to do a simple search, haven't done the search and co-pilot won't leave.
