Is there adaptor for the Surface Laptop Go 2 for downloading Photo from Sim Card
2023-03-06T20:37:02+00:00
Surface | Surface Go | Network
2023-03-08T03:00:50+00:00
Laptop: Microsoft Surface Laptop Go 2
Download to this device from SD Card
Adapter
Thanks for your response, Leonard Jones2.
Since Surface Laptop Go 2 does not have an SD card slot, then you need to get an SD card adapter that could go to the USB-C or USB-A port on your device. Microsoft Store does not have one available but you can get this adapter from any electronic retailers.
5 additional answers
    2023-03-07T01:01:26+00:00
    Hello Leonard Jones2,
    Thanks for reaching out to Microsoft Community.
    We understand how important for you to download these photos.
    Before anything else, we would like to ask some questions for us to come up with the best way to download your photos.
    • Which Surface model you have? Find out which Surface model you have - Microsoft Support
    • May I know where do you want to download the photos? Are you trying to export it to another PC or device?
    • Do you also mean you're trying to download it from an SD card? (Technically, sim card does not store photos or files.)
    • Were you trying to look for an adapter of an external drive for your Surface device?
    As much as we would like to give you some suggestions, but we may need some clarifications first for us to come up with the most accurate solution to your concern.
    We look forward to hearing from you.
    Regards,
    StevenK
    2023-03-07T17:30:16+00:00
    Adapter
    2023-03-10T22:15:00+00:00
    Thank you for your help
    2023-03-23T15:21:14+00:00
    The surface GO2 laptop does not have a SD Memory Cord Port but it has a USB TYPE-C Port so a USB TYPE-C Micro SD Card Reader/Adaptor can be used to back up data like one would using a Flash Memory Stick/Flash Drive.
