Surface Go 2 keeps dropping WiFi
2020-07-01T00:39:39+00:00
I have a brand new Surface Go 2 and it keeps dropping WiFi.
I can turn it off and back on and it works.  It's totally random and doesn't seem to happen after it's up for a while.  It's mainly right after a wake from sleep.  Sometimes it happens a minute after wake from sleep or longer.
All other laptops, iPads, TV sticks, smart phones and every other WiFi device I own does not have this problem.
I've ran the Windows diagnostics, and installed the Help App and ran that but no luck.
This thing must have a bug.
And yes, I've updated windows and installed all the firmware patches in the process so don't ask that question... :)
Thanks for any advice and please let me know if you are experiencing the same issue.
Surface | Surface Go | Network
2020-07-03T02:02:51+00:00
Update:
The changes below did not fix it.
I ended up getting it replaced by Microsoft and my new one is working perfect with zero drops.  I didn't change any settings on my Surface Go 2 or my router with this one.
My theory is my original Surface Go 2 overheated and the WiFi chip burned out just enough to cause drops.  Just a hunch... I had a thick case and Outlook was running for hours downloading a lot of history.  The Outlook database is IO intensive and I wonder if that caused it.  This is totally speculation but I don't know what else could have happened.  Or, perhaps it was just a bad chip from the factory. That can happen.
So if you experience WiFi drops and can't resolve it, it's probally time to replace the device.
Hope this help.
I believe I fixed it.
I don't have the LTE model so the Qualcomm driver is not present.
I do have the Surface Go M3 WiFi only model and here's what I did to turn off WiFi 6.
Device Manager > Network Adapters > Intel WiFi 6 AX200 > Properties > Advanced > 802.11n/ac/ax Wireless Model
Change Value to"3. 802.11ac"
It automatically reconnected
Since I have an ASUS WiFi router that supports AC this did the trick.
I tested speedtest.net before and got around 60Mbps.
After the change I got around 210Mbps.
So for I've had no drops and wake from sleep is pretty fast.
This looks like a bug with WiFi 6 not being backward compatible.  It works but not reliable or as fast as it should.
10 additional answers
    2020-07-03T22:59:07+00:00
    My Surface Go 2 wouldn't reconnect to wifi after going to sleep. I did what you did except I picked option 5, that seems like it fixed the issue.
    2020-07-07T04:29:33+00:00
    Hi MrDoode,
    Thank you for letting me know. You sorted it out. If you'd like this concern of yours to be sent as a feedback to Microsoft, don't hesitate to report this through the Feedback Hub app so that our engineers can do further experiment and check if there's anything to be updated just to take care of this issue.
    Kind Regards,
    Crest_Z
    2020-07-13T00:41:59+00:00
    It's back.  It seems to be related to inactivity.  For example, if I don't do anything at all for a few minutes or more, then I try to go to another webpage, it fails and I have to turn off and turn on my WiFi connection to get back online.
    Is anyone else experiencing this or is it just me?
    All my other WiFi devices (and I have over 10 at home including streaming devices) don't have any issues with WiFi.
    2020-08-24T02:14:59+00:00
    Is anyone else experiencing this issue?
    I can't seen to fix this.  I've tried everything I can think of.  Should I send it in for service?  I'd hate to get another one (probably refurbished) and find out it has the same issue.
    Do you recommending sending it in and what should I watch out for if I do?
