Surface Book 2 Memory Management BSODs
2021-02-04T15:46:26+00:00
I have a MS Surface Book 2 which recently has been experiencing "Memory Management" BSODs for the past 3 days.
The issue started on 1 Feb. I was using the laptop normally when it just randomly BSOD-ed, this then happened 3 times in a row that day.
Also the issue also started when I was playing MC Java on my laptop. Then I tried to do a system restore but it was BSODing also while performing the system restore. To fix the issue I also reinstalled Windows but that didn't fix the problem though. Finally I ran Windows Memory Diagnostic it reported a hardware problem.
Also the Surface Specs:
i5-8350U
Intel UHD 620 (Latest Driver was installed when the BSOD occurred)
8 GB RAM
Is there anyway I can get the Surface repaired/replaced here in India (Pune)????
(Note: Sorry if this post is in the wrong section, I am new to the MS Community (Forums).
    2021-02-04T16:16:48+00:00
    Hi DigiCraft66,
    Thanks for reaching out to Microsoft Community and posting your inquiry.
    Microsoft offers exchange process, when a device is exchanged a replacement unit is provided. To further assist you with this inquiry, we suggest contacting the Microsoft Surface Support. For India Supports, we suggest reaching out to Global Team
    If you have questions, please feel free to reply on this thread.
    Kind regards,
    John Neil_J
