Yes it is still on going.
Thank You
Wi-Fi internet not showing available networks.
Thank You
There are no ports on the Surface Go 2. No ports for a flash drive.
Do you any other suggestions?
That I can try, it worked fine before.
Then I didn’t use it for a few months
now it can’t find the WI-FI and I can’t open network connection.
Thanks.
Hi Jme!
Thanks for getting back to us!
If that's the case, I would highly suggest you contact our live Microsoft support team for further assistance already. They will be able to further diagnose the issue and provide more troubleshooting. Below are the steps on how to contact them:
Thanks again for choosing Microsoft. Hope this helps!
Regards,
RodelioP.
