Surface Book Performance Base - Crashing following MS Update
2018-01-13T06:31:09+00:00
On 12 January I rebooted my Surface Book with Performance Base, and was greeted with "Please wait while Windows 10 performs updates - 0%..." screen.  When the system restarted, under the "SURFACE" white text on black boot screen was a colored progress bar which is usually not present after windows updates, so I assume this was the Spectre/Meltdown firmware update.
However, since then my system has been incredibly unstable - in fact, the first crash was about 5 minutes after the Update was installed (interestingly, after the first crash a different colored progress bar was under the "SURFACE" white text on black boot screen - looking at the update notes, it was supposed to reboot the system twice but the second reboot was the result of a crash).
The crashes occur at least every hour and only twice have they been accompanied by an error message (one of the two was "Paged fault in non-paged area"), but the rest of the time the crash is just the display going black (occasionally accompanied by a buzz from the audio speakers).  The system is still running, as it requires a 10 second hold down of the power button to switch off.
My guess is that one of the firmware updates is either not optimized for performance base or was installed incorrectly, but unfortunately I don't have a recent restore point to roll back.  It's incredibly frustrating to try and get any work done (in fact, it crashed while I was trying to submit this question).
Is there any way to diagnose the fault without doing a complete system restore - I'm travelling in an area of very poor internet quality, so wiping the system and reinstalling all the programs is pretty much out of the question.
    2018-01-27T20:44:55+00:00
    Got a different system back from repair depot, as expected, it was clean and undamaged.  It wasn't updated so I spent a couple days updating it fully before installing any of my normal tech stuff.  Here's what all that was:
    Start (new) Version Information
     Embedded controller: 90.1277.256.0
     UEFI: 90.1427.768.0
     Touch: 53.0.94.0
     Wi-Fi driver: 15.68.9112.23
    Updates 1/26/18
     20 drivers
      Intel(R) Corporation - System - 9/21/2017 12:00:00 AM - 9.21.0.2853
      Surface - Firmware - 9/14/2017 12:00:00 AM - 90.1837.256.0
      Surface - Firmware - 12/6/2017 12:00:00 AM - 91.1926.768.0
      Intel Corporation - Display - 9/23/2017 12:00:00 AM - 22.20.16.4811
      Intel - System - 7/18/2017 12:00:00 AM - 11.7.0.1040
      Intel(R) Corporation - MEDIA - 7/17/2017 12:00:00 AM - 10.22.1.102
      Surface - System - 10/31/2017 12:00:00 AM - 2.27.136.0
      NVIDIA - Display - 10/19/2017 12:00:00 AM - 23.21.13.8808
      Realtek Semiconductor Corp. - MEDIA - 9/1/2017 12:00:00 AM - 6.0.1.8242
      Surface driver update for Surface Camera Windows Hello
      Intel driver update for Intel(R) Imaging Signal Processor 2500
      Intel Corporation driver update for Microsoft Camera Front
      Intel Corporation driver update for Microsoft Camera Rear
      Intel Corporation driver update for Intel(R) Control Logic
      Intel Corporation driver update for Intel(R) CSI2 Host Controller
      Intel Corporation driver update for Microsoft IR Camera Front
      Intel driver update for Intel(R) AVStream Camera 2500
      INTEL driver update for Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
      INTEL driver update for Intel(R) 100 Series Chipset Family PMC - 9D21
     8 quality
      KB4056891
      KB4023057
      KB4056887
      KB4053580
      KB4033631
      KB4049011
      KB4054505
      KB4035543
     1 other
      KB890830
    Updates 1/26/18
     1 quality
      KB4057144
     2 driver
      Surface - Firmware - 9/14/2017 12:00:00 AM - 5.62.3126.2
      Surface - Firmware - 9/11/2017 12:00:00 AM - 11.7.4.3330
    Updates 1/27/18
    Feature update to Windows 10, version 1709 (Fall Creators Update)
    Updates 1/27/18
     quality
      KB4056887
      KB4056892
      KB4041994
    final Version Information
     UEFI: 91.1926.768.0
     Touch: 53.0.94.0
    created a recover disk, set up backup, and began installs of my stuff, so far no issues.
    I'm inclined to think one of two things, either there was a firmware update that was incorrect and subsequently fixed or my system just didn't like the firmware for whatever reason.  There were never any errors or indicators that pointed to the actual issue and re-flashing firmware oldest to newest didn't work.  I do find it unfortunate that MS couldn't resolve the issue remotely and that replacement was the cheapest, fastest method, I'd like to know what the real problem was, I can be glad it was in warranty, not sure what they would have done had it not been since they do cover windows update issues pretty well and free.
    Good Luck to anyone else with this issue, hopes this helps. K
