Download stand alone InfoPath Filler for InfoPath 2013
Boykin, Lavester 20 Reputation points
2025-07-02T19:21:26.1966667+00:00
Microsoft 365 and Office | Development | Other
2025-07-03T03:26:42.6466667+00:00
Hi Boykin, Lavester
Thank you for reaching out through the Microsoft Q&A forum. Following your inquiry regarding InfoPath Filler 2013, please find below the recommended steps based on your current installation status. Kindly note that due to the absence of a dedicated InfoPath testing environment, the instructions provided are theoretical and derived from publicly available documentation. Actual results may vary depending on system configuration and licensing.
  • If InfoPath Designer 2013 is already installed on your system, you can add InfoPath Filler by modifying the existing installation: open the Control Panel and go to Programs and Features, locate Microsoft InfoPath 2013, right-click it and select Change, then choose "Add or Remove Features". In the feature selection screen, make sure InfoPath Filler is set to “Run from My Computer”, and proceed with the installation to enable the Filler component.
  • If InfoPath 2013 has not been installed, you can download the full installer from the official Microsoft website, specifically the version for Office 365 ProPlus Subscription available through the Microsoft Download Center. During installation, be sure to select Customize when prompted, then choose to install InfoPath Filler. Please note that activation may require a valid product key or an active Office 365 ProPlus subscription, depending on your licensing arrangement.
For further assistance or licensing inquiries, please contact Microsoft 365 Sales and Support | Microsoft 365. I hope the details provided will assist you effectively.
0 additional answers
