Question. I've a Surface Laptop 3 Model VAC-00022. I've a Surface Dock 2 that displays 2 external monitors correctly. I'm hoping to use the USB-C from the laptop itself to display a 3rd monitor. I tried buying a USB-C to HDMI cable but that doesn't work. That probably doesn't work because the other 2 monitors are USB-C to HDMI from the Surface Dock 2 itself.
Does anyone know how to get a 3rd external monitor, so a total of 4 screens (with the laptop screen working as well)?
I think it may have to do with the dock itself. I have the newer surface dock with 4 USB C ports (2 in the front 2 in the back) and cannot get a 3rd monitor to work with my surface pro 7 (3 monitors + the surface itself). I work in an office and 3 of my co-workers have surface pro 7 set ups with 3 or 4 external monitors. They all have the older dock that has 2 mini display ports in the back and 2 USB 3.0 ports in the front. This is the only thing I can think of that may be causing the issue because otherwise our set ups are the same but I cannot get the 3rd monitor to work.
