I tried to change DNS servers, using private browsing etc etc with no result-
Duo 2 stops randomly accessing the Internet at any moment for indefinite time, I have checked even with apps out of any browser.
My Surface Duo 2 loses randomly ability to browse the web. The Edge or Firefox are unable to navigate and a ping test shows lots of errors appearing randomly. It can be after several hours without any issue, or stay wrong for long whiles. Both browsers fail exactly the same and they don't interfere one the other, it happens the same if you close one of them.
Latency uses to be too high even when it is working OK, and for instance a 64byte ping round delay is about 30-60ms in 5G depending on coverage quality (which still seems to be a lot slow for NR-NSA!) and not much more in 4G (40-80ms). In fact latency in 5G is hardly distingushable from 4G. My Surface Go LTE pings last about 3ms in the best case and up to 30ms in 4G, so the Duo 2 is really slow even when its Internet does not crack. But when it does, it stays many minutes with random behavour and a lot of errors, ping lasting to to 300ms or more or just not reaching, or, when browsing, simple unable to reach the target website.
The Surface with LTE with me checked repatedly does not give any error in the same locations and moments.
I tried by changing several adjustments without any result:
The only thing that works normally (but not always) is to switch the phone off and on. Just to add, the problem happens also more after moving from a place to other, outdoor to indoor or vv, but also not always.
I am not sure if the cuts are for the complete Internet connectivity or only to reach IP addresses / DNS's. I know only from the browsing and the ping.
I called to the support and somebody asked me to return the device. This is very disturbing for me as I use the phone continuously and I have installed my work apps. I think there should be some SW adjustment or restoring tat could be tried.
I have the phone since november and the problem is more or less since the beginning but I think that it happens more and more often as times passes.
In january I installed to the phone the Slim Pen Cover which covers the front face and allows to charge the pen magnetically or via NFC or both (I am not sure). I wonder if this is penalizing the antennas coverage / performance.
Celular network adjustments
Preferred type 5G (or any other, the problem remains the same)
Adjustment version 21407-113594371.113594371 (I ignore what is this)
Used net 5G NR NSA
SIM data (SIM 1):
Signal level typ -90...-85dBm 50..52 asu (up to -60 at times in 4G/3G(
Phone data:
Microsoft Surface Duo 2
HW version MP retail (12)
Touch Version 26.302.139
Compilation data 2021.1116.111
SO data:
Android 11 updated Jan 1 2022
APN
private DNS no (or auto, the problem remains the same)
Errors happen also in Wifi, but less frequently and possible due to bad coverage.
What happens with cellular data is different. Always, and only when, I start to browse pages, there is a moment that errors start to appear as if some cache were corrupting or so, finally the new pages are not loaded and... wait that the effect stops (sometimes it is solved by switching power off/on, smetimes not).
I think (using ping testers) that the errors are for any Internet access, not only browsing, but it looks like if most of the errors only start to appear when browsing web pages.
I have tried dozens of cellular and browser configurations, including private browsing, strict protection against trackers etc. with no success at all, the problem is independent of it.
I am spending more time testing than using my phone for what I need it.
The way the navigators load the pages are not so nice anyway. In my old Lumia, I started to see some contains from the moment the progress bar starts to move. Here, I don't see anything until the bar reaches the end.
Of course when it fails it never reaches the end. Uses to stop in 10-30% of the lenght, both with Edge and Firefox.
I have tested the SIM in my old mobile (a Lumia 950XL by the way) and it works fine. So no need to try with another SIM, or eSIM.
There is something wrong in the Duo 2 Internet access software I guess. Or hardware errors.
I am in need of a solution. Please. I have a repair order open since Feb 14 but MS staff told me here not to go ahead with it yet.
Have you tested Google Chrome? It's pre-installed.
