I am checking all the time the failure so I can add some data...
- I ckecked the SIM configuration with the operator and it is fine
- errors appear normally after browsing for some minutes, at ant time of the day, and any place
- I have observed a strange behaviour as to the failures and the network type handover (between 5G/4G/3G). For instance, yesterday I was in a town with poor 5G coverage. The phone didn't switch to 4G (or 3G, as here is common that we have more 5G in 4G gaps because of a operator policy that makes use of 5G to extend total coverage) even if the signal level was very poor (-100dBm). Then, ping check errors started to appear but the mobile didn't switch to 4G or 3G yet. Then I passed inside a house, and the phone inmediateñy switched to 3G... and the 3G signal level was -50dBm! I have experienced the same more than once, having errors outdoors and coming to a better behaviour indoors (but with very long delays anyway)
Another curious issue is that most of the times when I change the preference for 5G to 4G (thus discarding 5G) the phone goes inmediately to 3G. But if I switch the phone off and on, it goes to 4G. It is remarkable because I checked this in 3 places that typical signal values indoors are: 5G -100dBm, 4G -90...-95dBm, 3G -50dBm!, 50dB difference between 3G and 4G/5G. What to think about the antenna coverage?
Please, I would be very thankful if MS technical staff can help me. I have already opened a service order to send the phone in guarante but I would be very happy to discover tht it is not necessary.
